Thread: Solar cover vs. solar panel(s)?
    Jun 2015
    Chardon, Ohio
    12
    Looking to heat my pool using solar energy, but not sure which route to go. The costs seem fairly similar either way (probably a bit more for panels), so I thought I'd see what you all would recommend based on your experiences.
    Thanks!
    Jeremy
    30ft round, 21k gallon AG Vinyl Pool, Doughboy Powerline XP I Series 1Hp single-speed Pump (0-3296-203), Doughboy Silica II Sand Filter (0-1750-000)
    Taylor K-2006 Test Kit with SpeedStir
    Donldson's Avatar
    NW Ohio
    2,892
    Re: Solar cover vs. solar panel(s)?
    Actually, a solar cover is a bit of a misnomer. It's main temperature benefit is insulating the water, especially at night. Solar blanket would frankly be a better term. The pool warms up by day and the cover slows the heat loss at night.
    Solar panels on the other hand actively heat the pool. The name of the game with those is square footage. The more there is the more solar energy they are collecting and the warmer the water. I don't know what you run schedule for your pool is but with solar panels you will need to have it running during the day and off at night to see the maximum benefit.
    You probably will want to either get the solar cover alone or get both, since you can lose a lot of the heat you generated during the day overnight without a cover.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    unless they meant a solar dome...
    http://www.craigbartlett.com.au/pics/32/32741b.jpg
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
