Thread: PH Stuck
    Sep 2008
    Jacksonville, FL
    105
    PH Stuck
    I have been testing my PH ever couple of days here lately. It keeps giving me a 7.8 result. I then go to the Pool Calculator to determine how much acid I need and then add that amount. I have done this 3 times over the past week and every time I check it, the PH is still at 7.8. Could this be because of my high FC from my recent shock?
    Here are today's test results.
    FC - 19
    CC - 0
    TC - 19
    PH - 7.8
    TA - 80
    CH - 360
    CYA - 70
    Salt (SWG) - 3500
    Salt (Strips) - 3460
    Borates - 30
    Temp - 69
    Thanks!!!
    16,500 Gallon Plaster, Pentair WhisperFlo WF-26 1 1/2 HP Up-Rated Pump, Pentair Clean n Clear 150 Cartridge Filter, BioGuard Mineral Springs MS-10 SWG, Hayward Navigator Cleaner, TF-100 Test Kit, Apollo Magnetic Stirrer
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: PH Stuck
    You got it I overlooked the high cl when I said your water is out of balance However, since you had scaling you had to drop the pH some anyway. I wouldn't trust the pH test until the cl is closer to 10.
    Sorry about my oversight but even if you get a little more scaling on the tiles while waiting for the cl to drop - you know how easy it is to remedy
    Luv& Luk
    -Ted
    Guest
    Re: PH Stuck
    If your FC is as high as you say and you are reading a pH of 7.8 then your actual pH is MUCH lower than that! I would not add any more acid and would check the pH as soon as the FC is below about 12 ppm!
    Sep 2008
    Jacksonville, FL
    105
    Re: PH Stuck
    Great.... I did not know that. Thanks guys!!!
