Results 1 to 11 of 11
Thread: Persistent Algea with successful SLAM?
    Mar 2015
    Gainesville,FL
    5
    I have the same issue. A green pool even though my FC is consistently 3-4 and my CC is 0. I have a SWG and sand filter and last night i put a cup of DE in the skimmer to try to help it get the smaller stuff.
    Based on reading here, even though the CC was zero, I figured it must be algae so I decided to SLAM it. I went ahead and dumped in 8 gallons of bleach last night and got the FC up to about 20. Should I continue this or am I on the wrong track?
    What is the solution if it is indeed pollen? Shouldnt the filter be able to handle it?
    18,000 Gallon in ground pool with SWG
    Plaster surface, Maytronics Z5 robot
    Multi speed pump, Hayward sand filter
    TF-100 test kit
    K-1766 salt test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: Persistent Algea with successful SLAM?
    Without knowing your CYA level we don't know if you have reached shock level or not.
    We base our advice on accurate reliable testing and your 5 way kit won't provide the numbers or accuracy we need. We have found that tests based on the Taylor reagents provide the accuracy needed.
    Pick up a TF100 as it is the best value in providing the reagents you will need for the SLAM plus have enough left over for a lot more testing
    TFTestkits.net
    Support the site
    30,432
    Welcome to the forum.
    But you did not SLAM it. You only added a large dose of chlorine. The SLAM process is just that.....a process that can stretch out for days and you must hold you chlorine high the entire time.
    A picture of your pool water would likely be a big help and then posting ALL your test results would be an even bigger one.
    Mar 2015
    Gainesville,FL
    5
    Right, I just started the SLAM last night, but am considering abandoning it if Im on the wrong path. With CC=0 is a SLAM the right course? Ill take pics tonight. Here were the test results before I added the 8 gallons of bleach:
    FC=3
    CC=0
    TA=130
    CYA=50
    salt PPM = 3500
    I updated my signature to show that I now have the good TF test kits.
    Thanks!
    TF-100 test kit
    May 2014
    Franklin, NC
    9,216
    You need to follow the SLAM instructions completely until the end.
    Support the site
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by Byra View Post
    FC=3
    CC=0
    TA=130
    CYA=50
    salt PPM = 3500
    Thanks!
    ok, so what is your FC after you added the bleach? are you losing FC rapidly? if you tested your FC 1/2 hour after adding it and its say 25ppm (not knowing the number, just for argument sakes) and then you test it after 2 hours and it has dropped a lot, you have an algae problem. if you its pretty steady, then test again after sundown, record it and then test again before first light in the morning. This is the OCLT. if your FC drops less than 1ppm your pool is good and you don't have an algae problem.
    report back
    if its POLLEN, you need to vacuum/filter to get rid of it is all
    Last edited by DaninFLA; 06-05-2015 at 02:22 PM. Reason: fixed typo...meant POLLEN, not algae
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    May 2014
    Franklin, NC
    9,216
    Quote Originally Posted by DaninFLA View Post
    report back
    if its algae, you need to vacuum/filter to get rid of it is all
    I agree with everything but the last sentenance. Filtration has nothing to do with eliminating live algae. Now, if it's dead algae - fine.
    Support the site
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by tim5055 View Post
    Doh! meant pollen, not algae! editing now, good catch
    Dan
    Mar 2015
    Gainesville,FL
    5
    I did the OCLT test 2 days ago and it dropped by 1 ppm. Thats another thing that makes me doubt its algae.
    Is it even possible that pollen can turn the water green? Maybe if my pump is unable to keep up?
    TF-100 test kit
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    does it brush off really easily? If so, probably pollen. pollen comes in lots of colors, green is one
    Dan
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    The most important part of the SLAM is the M for Maintain - as in maintain FC as close to the target FC for your CYA as you can until all the criteria of the SLAM are met.
