Results 1 to 13 of 13
Thread: First reading with the TF-100 - whats next
    Dec 2014
    Edmond, OK
    82
    So I was able to get my pool filter replaced with a Pentair Sand Dollar. I got my TF-100 and here is my first reading. The pool company shocked the pool with Cal Hypo while I was out of town. The swamp is now a very white/blue murky color. Last week I drained about 1/3 of the pool to lower my CYA which was reading above 150 on the Test Strips.
    FC - 7
    CC - 0 or 7 not sure how to report it
    CH - 500 (probably off)
    TA - 200
    ph - 7.2
    CYA - 100 ---- UGH!!!
    So other that probably needing to drain more water and replacing to lower the CYA. How can I get rid of the murkiness and lower my TA?
    Thank you!
    30,000 gallons, in-ground plaster, well water, Hayward tri-star pump, Pentair Sand Dollar SD80 filter. TF-100 kit
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: First reading with the TF-100 - whats next
    if your CYA says its 100, it could be 100 or it could be 500. the test only goes to 100. you will have to dilute and test again and multiply by two. I.e, use half pool water and half tap water, fill to the bottom of label, fill with the reagent to top of label per instructions. are you shaking it and waiting at least 30 seconds to do the test? with dilution method, if you get a CYA of 60, then you have 120. if its 100 again, going to have to dilute again.
    the CYA takes a while to get right. make sure you watch the instructional video and duplicate. then retest again with new sample to make sure its accurate. would hate to have you drain the pool to only learn the test wasn't done right.
    that said, if you have been using pucks your CYA is most likely too high and will need to drain pool to lower it.
    if you added the 5 drops after your FC test and it didn't turn pink...your CC is 0
    other numbers look good at least
    don't worry about your TA right now. its a bit high, but can worry about that later.
    the solution to your water issues, is to first get CYA under control and then SLAM. start reading up on the SLAM procedures. if you are patient and follow it, it will work 100% of the time
    next item to do...provide your notice to the pool company that you will no longer need their services
    next item after that...start stocking up on bleach. you are going to need A LOT. would get at least 20 gallons to start. will need more, but will get you going once CYA figured out
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    I highly doubt your CC is 7. But just to be sure, you ought to watch the how-to video to make sure you're testing chlorine correctly.
    The high CYA is most easily reduced by draining and refilling. Sorry. It is a linear thing. Replace 1/3 water, lower CYA 1/3. It worked out once for you. You probably ought to run a dilution test so you get an accurate reading so that you replace enough in one shot. Post 8 step 9. Do it right and never have to do it again.
    The TA will come down over time as you adjust pH. It's the last thing you worry about. First you need to kill the algae that is causing the cloudiness.
    Drain and refill to get CYA to a reasonable number. Then follow the SLAM directions to clear the water. And then fine tune the rest.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Work on lowering you CYA to 30-50 range. 30 is better so you use use less bleach. Don't worry about TA right now.
    You will be doing a SLAM once your CYA is low enough.
    You want CC to be .5 or lower. After testing FC in 10ml tube and water goes clear after drops of 0871, you then add 5 drops of 003 and if it turns pink then you add drops of 0871 to make it go clear. You multiply the drops by .5 and that would be your CC.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    one more thing. once you figure out your actual CYA...be careful filling the pool. you have a large pool and you are on a well. unlikely you can do a 50% refill (15,000 gallons) from a well without possibly running your well dry and causing mechanical issues and lack of water for your house for a few days.
    Dan
    Dec 2014
    Edmond, OK
    82
    Only reason I think the CC is accurate at 7 is because he put 10 lbs of the cal hypo and it was completely green and now very white. My assumption could be way off though as I am no expert. I agree though - wont hold on to chlorine with the CYA that high.
    Not too concerned about running well dry - we have had an incredible amount of rain. Otherwise yes, it would be a concern. Its more a frustration for how long it takes to drain and refill.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    if your CC is 7, really doesn't matter at this point. either way you are going to have to SLAM, so process is the same
    Dan
    Dec 2014
    Edmond, OK
    82
    2 things:
    1. Is it okay to use my Kreepy Krauly during slamming? I am noticing that my KK is reducing my psi from 20 down to 15psi.
    2. Should I not even bother SLAMing since my CYA is obviously too high?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You can add bleach to keep your FC from dropping too low. However, I would not SLAM until your CYA is much lower.
    Just brush for now unless you can see the bottom then use the keeps crawly when you can see the bottom better.
    Lisa
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by jordanlanderson View Post
    2 things:
    you cant SLAM without knowing your CYA. do the dilution test on the CYA and report back. for now just try and keep your FC up to slow down any algae growth. either way you are going to be refilling unless you have access to a chlorine main line pumped directly into your pool
    say your CYA is 100 (probably higher). your SLAM CYA level is 39ppm. for a 30,000 gallon pool, to raise your FC from say 5 to 39 will take nearly 12 gallons of 8.25% bleach! and that's just the first drop, then two hours later you are going to need another 6 gallons probably. you really want to do that for a week or so?
    determining your CYA is critical
    for now try and keep your FC around 15ppm.
    Dan
    Dec 2014
    Edmond, OK
    82
    So I just did the half tap water and half pool water and my CYA came out right around 60. So it would seem that my actual CYA number is around 120. Ugh - another drain and refill of about half the pool I guess.
    Thank you everyone for your help!
    Dec 2014
    Edmond, OK
    82
    I also added 386 fl ozs of 8.25% Chlorine. Waited 30 minutes and cheked my FC and it is reading at 17ppm. Should be able to start draining later today.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    good luck, draining/refilling has got to suck. but after you get CYA under control, will never have to do it again
    ouch. also remember that the accuracy of the CYA test decreases at higher numbers. it could be plus/minus 20 I bet. I would do 2/3 drain if you are able to do it. would stink to do 50% and then you come back and your CYA is 65 or something and you have to drain again. I would bite the bullet and do more and not have to worry about doing it a second time.
    make sure to check your water table first, don't want to float the pool! dig a hole next to your pool to see where the water fills up to and don't go much lower than that
    Dan
