Thread: filter upgrade
    Jun 2015
    galesburg illinois
    3
    filter upgrade
    I have a 16x48 intex pool that I have not filled yet have been reading that the filter it came with is not adequate my question is should I get a sand filter and if so what size ? The description of the pool states its around 5000 gallons depending on how full.
    16x48 intex ultra pool metal fame
    Apr 2015
    Rocky Point, NC
    14
    Re: filter upgrade
    I am using a Hayward S200 sand filter on mine. If you are not planning any upgrades, ie through wall skimmer. I would use the 2500 gph intex sand filter pump combo.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: filter upgrade
    The filter will work. It's just small and will need much more servicing (cleaning). If you can afford it to upgrade go ahead. It's a seasonal pool, cartridge filters are light easy to store in the winter. Filter models all have their pros/cons.
    Pool School - Pool Filter Comparison
    Pool School - Maintenance and Cleaning of Pool Filters
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,552
    Re: filter upgrade
    I have the same pool. I added the 1600 GPH pump with 16" sand filter, and it does fine. But if the 2500 GPH is available, go for it. They didn't have one in stock when I bought mine, or I likely would have gotten the larger one. But either is a vast upgrade from the cartridge filter.
    Next, get a Hayward Dyna-skim thru-the-wall skimmer. It keeps so much more debris out of the pool, you won't believe it. Plus it comes with a much better return eyeball and an adapter so that you can use a real pool vac. Don't be afraid to cut the holes in your liner. It's simple and you won't ruin it. Just take your time with an Xacto knife. There are many threads here on how to do it.
    Lastly, I like my SWG immensely. Add salt, get your water balanced, and forget about it. Just test every few days. I don't recommend the pump/SWG combo units. Eventually one or the other will quit, and you'll be stuck replacing both. Get the standalone unit instead.
    That's my suggested order of upgrades - pump/filter, skimmer, then SWG. Congrats and enjoy that pool. We love ours!
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
