Thread: $$ Daily bleach consumption $$
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    I use 10% chlorinated liquid purchased from Lowe's with good results. Test hold true after adding.
    My daily cost of adding it is around $1.29 daily (adding around 5 cups daily)
    I'm losing about 2 to 3 ppm daily with only 0.5-1ppm lose overnight. CYA around 30-35. Thinking about bumping up CYA to around 40-45 to get better protection on FC. Water is crystal clear. What do you think?
    FC-3
    CC-0.5
    PH-7.6
    TA-100
    CH-250
    CYA-30-35
    BORATE-45
    TEMP-84
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
    Jun 2014
    14,970
    Re: $$ Daily bleach consumption $$
    Rick, I'm near San Antonio and I just started bumping my CYA up from 30 to closeer to 50 just because of the glaring sunlight. My pool is in the open all day long and takes a beating, so I wanted a little more sunscreen (CYA) to protect my chlorine.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Yep, raise that CYA. Every two 3" trichlor pucks you add will raise CYA by about 5. That's the easiest way to do it unless you have some stabilizer laying around.
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Yeah, I get about 9 hours sunlight on pool daily now and its up around 90 degrees here in Dallas area. Will try pucks since I don't have any stabilizer on hand. Thanks
    Rick T.
