Thread: Quick FC/CC Drop Test Question
    May 2015
    South Florida
    10
    I have a quick question on the TF100 FC/CC drop test. I did a test and forgot to clean the tube out right away and I noticed that after an hour or so the clear liquid turned back to pink. This is normal right? Just want to make sure I am not testing incorrectly. Thanks!
    20k? gal, IG plaster, 3HP Pentair Intelliflo variable pump, Hayward cartridge filter, built in 1987 with spa but currently have no heater.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Re: Quick FC/CC Drop Test Question
    Quote Originally Posted by Sir Thomas Hobbes View Post
    Yes - completely normal. The initial color change is the one you are interested in.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Jun 2014
    15,298
    You should be fine. It is advised to take/use the readings immediately after doing the initial drop test to measure FC. Once the liquid is clear, follow-up immediately with the CC test then discard the liquid. Anything you may have left or forgotten about after your testing is invalid and just waste.
