Thread: Sand Filter Leaking
    off2theocean's Avatar
    Sep 2014
    North Carolina
    12
    Sand Filter Leaking
    Hi,
    I have noticed that my sand filter is leaking from under the multiport and under the band where it connects to the tank. It is only leaking on one side. Is there an easy fix for this? It is a not really a leak - more like a slow seep. I haven't noticed any pressure changes. There is also no water leaking out of the backwash hose so I think the multiport is fine.
    The PB changed the sand in the filter after the replaster. I don't know if that had anything to do with it.
    Near Winston-Salem, North Carolina
    33,000 IG Freeform Gunite * Pentair Tagelus Sand Filter * Hayward Pump
    1970's Build * Resurfaced 2015 w/Krystal Blue Krystalkrete
    Polaris 380 Cleaner * TF-100 Test Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,176
    Re: Sand Filter Leaking
    To be honest, a small weap like that would not bother me and I would just let it go. Sometimes the fix is worse than the problem.
    To fix it you would take everything apart, and lube the o rings or replace them.
    Support the site
    Sep 2014
    North Carolina
    12
    Thanks! That makes me feel better.
    May 2014
    Franklin, NC
    9,176
    Another thing I have thought of with mine is that it may be condensation, not a leak.
    Support the site
