Results 1 to 8 of 8
Thread: Adjustable Inlet Eye
    Apr 2015
    South Central PA
    297
    I have a fixed inlet eye on my pool. When the water is about halfway up the skimmer, the inlet is just below water level, which can cause water to go on top of the solar cover (depending on wind, etc). I was considering replacing it with an adjustable inlet eye, but I'm not sure why this wasn't done to begin with. Is it a good idea to point the inlet slightly down, or should I just leave it alone?
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    30,415
    Re: Adjustable Inlet Eye
    I don't think many of us understand what you are talking about....got a pic? What is the purpose of this "inlet"?
    Apr 2015
    South Central PA
    297
    Jun 2014
    15,070
    When I think of adjustable "eyes", I'm thinking of the adjustable return jet eyes. Is that it, or is there something else on your pool?
    That looks like a return jet eye to me. Right?
    Apr 2015
    South Central PA
    297
    Yes, it's the return jet- sorry, I'm not familiar with the correct nomenclature yet....mine isn't like the one in the picture- the eye doesn't swivel
    Jun 2014
    15,070
    It can be misleading for sure. When I read the web page and it said "inlet", it had me second guessing myself. Many TFP'ers will adjust some of their returns slightly downward to promote agitation and movement of water near the bottom of their pool. I don't see a problem with installing one and pointing it slightly downward. Anyone else have comments?
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    I would replace the return jet with the one you found then adjust it, as already pointed out, in a slightly downward direction. Also, adjust it so the water circulates past the skimmer(s). You can test the circulation with a handful of packing peanuts tossed into the pool.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Apr 2015
    South Central PA
    297
    Thanks. I just wanted to make sure there wasn't some reason that I wasn't aware of for the fixed return port.
