Thread: Pump GFCI Question
    Pump GFCI Question
    My pool builder wired my pump with a GFCI. The circuit trips very randomly and I was told by other people in the industry that it should not have a GFCI as with a variable speed pump it can trip the circuit when the pump speeds up. I have asked others and get answers both ways. The pump is a Jandy JEP2.0 and is just under 2 years old.
    If it is suppose to have a GFCI does anyone have an idea why it trips randomly? It trips probably one or two times a month with no pattern that I can figure out.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Pump GFCI Question
    Assuming that your pool is 2 years old then, yes, the NEC requires that your pump be connected to a GFCI protected circuit.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The GFCI is required by code. Normally the first thing to try is a different breaker to see if the original is bad.
