Thread: New from Canada
    Jun 2015
    Winnipeg, MB, Canada
    281
    New from Canada
    Hey all,
    I've been reading the forum for awhile and decided to finally join. I bought a house with a pool 2 years ago (moved out of one with a hot tub) and the previous owners hadn't covered the pool for the long Canadian winter so when I tried to get it going the pool store was no help and kept selling me things. I went on line, found you and within a few days my green swamp was a blue paradise. Swimming season is short enough here, so I like to do as little maintenance as possible. After getting it going, I just had to add some chlorine every day or two. Very easy to do.
    I'm looking to buy the TF test kit this year (the pool store has been doing my testing, but it's inconsistent, I fear; plus they might notice I haven't bought anything from them in over a year). Unfortunately doesn't ship to Canada and the Taylor Kit is about $200 from the distributor up here. Trying to import the TF kit but wondering if anyone know if it is made in the USA? If it is I can import it here for free, otherwise I'll have to pay double in duty.
    I also put up some solar heating panels this spring so those should cut down my heating bill, I think the Jandy Lite 2 that I have is pretty old and inefficient, maybe I'm wrong though. One of the panels had several leaks in it out of the box, so I'm working on getting it replaced but the other five have helped immensely thus far.
    23K gallon, vinyl liner, 1hp pump, 300 lb sand filter, Fafco solar panels, jandy lite 2 heater, TF-100 Test Kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New from Canada
    Welcome to TFP. Sounds like you've been busy.
    I'm sure someone will chime in about importing the TF-100.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New from Canada
    Welcome to TFP!
    Others from up there have gotten them somehow, from friends or visits here, but yes they are made in the US. North Carolina to be precise.
    Essential Links:
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    Re: New from Canada
    I ran into the same problem with the test kits. I ordered one when we were in Florida to avoid the Canadian prices but replacement reagents are a problem too as Taylor won't ship them to Canada either. The Canadian distributor prices are so high that he can't be selling any.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
