Yes, you could purchase a separate ammonia test which is usually available at stores that sell aquariums. However, the tests you have run with the TF-100 confirm ammonia - without a doubt. You will do a SLAM, but the one modification I mentioned earlier, when dealing with ammonia, is to intentionally begin it with 0 CYA .Mcecere11 said:When I read the pool school how to SLAM it says be careful when cya is 0. It also doesn't really give a FC level for 0 cya. I have a swg, do i just follow the lowest cya recommendation (60) which has a shock level of 24? assume that it will take a lot of bleach...also anyway to test for ammonia or is it just a given since i have no cya and cc is super high and FC is basically non-existent?
No. You go by the actual CYA currently in the pool to determine both the maintenance and shock FC levels. For the purpose of this particular SLAM and the current water status of your pool, it is irrelevant that your pool is SWG.Mcecere11 said:I have a swg, do i just follow the lowest cya recommendation (60) which has a shock level of 24?
Here's the SLAM procedure that you need to follow:
- Dose pool to shock level of 10 ppm FC
- Do not add any CYA until chlorine begins to hold
- Test FC every 30 minutes until chlorine begins to hold. Add FC as needed to get back to shock level. We will define an FC of 3 ppm as "chlorine beginning to hold"
- When FC is at or above 3 ppm after a 30-minute test, add 30 ppm of CYA - use Pool Math for dosing amount.
- Increase the FC target to 12 ppm and continue the SLAM as directed in the SLAM article until the SLAM criteria of "Done" are all met. Test FC as directed in the SLAM article - no need to continue testing at 30-minute intervals at this point.
BTW, leave your SWG off during the SLAM. Use bleach for chlorine until you are done SLAMming.
