Thread: New plaster with divots and pock marks?
    Shreveport, LA
    46
    Hi Guys,
    On our newly plastered pool (less than 2 weeks old), is it normal to see pock marks and divots on the bottom or is the entire surface supposed to be smooth? I'm not sure how picky to be, but it seems these divots are rough and going to be great places for algae to grow on...
    It was hard to notice until the water cleared up and we actually turned on the pool light which cast shadows and is showing all the imperfections.
    Thanks!
    20,000 gallon, free-form, plaster, SWG, Hayward Pro Series sand filter, Dolphin Discovery
    38,457
    Re: New plaster with divots and pock marks?
    Ideally the entire pool would be completely smooth ... sounds like shoddy work.
    Jul 2014
    Gilbert/AZ
    27
    Sounds like someone forgot to switch his shoes from spikes to sponges before he floated his way out.
    Owner-Builder, 13,500 IG StoneScapes Mini Pebble (Aqua White), Pentair 160301 Cartridge Filter, Intellichlor IC40, Intelli pH system, Intelliflo VS pump, Startup 2/26/2015
    Shreveport, LA
    46
    I should add that there are larger sized pieces of hardened plaster stuck to a few spots on the walls (even with twice a day brushing), stains around the light, stains around one of the returns and part of the wall around the light is as rough as sandpaper.
    Hemess's Avatar
    Norman, OK
    95
    That is not normal. Mine is smooth as a baby's booty. Doesn't hurt feet, etc. not saying there aren't a few imperfections here and there, but you would have to search hard. Hope that helps.
    28,000 IG, gunite, IntelliChlor IC40 SWG with SPA,
    Intellichlor/VS Pentair
    Norman, OK
