Thread: Is this normal?
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    456
    Is this normal?
    I have been slamming my pool for the past week, and am seeing a VAST improvement in the water clarity...
    My question has to do with the CYA level... I don't see ANY CYA in my pool, however after a full day of sun, my FC only dropped 5ppm from 16 at 6am to 10.5 at 6pm.
    Without any measerable CYA, is this a normal drop? I expected the FC to be a LOT lower this evening.
    levels at 6pm
    FC 10.5
    CC 0
    TA 80
    PH 7.2
    CYA <20
    I have had 0 drop in FC in the overnight drop test for the past 3 nights straight.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Is this normal?
    There really isn't a normal. You are doing well with that little loss, so you must be getting close. You can up it a little if you like and see if a little more Cya helps. Looks like you are just waiting to clear now.
    Welcome to TFP, and congratulations for taking the ball and running. Good job!
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,604
    Re: Is this normal?
    Mine loses 4 ppm daily and lots here don't consider that to be "normal".
