Thread: First test with TF-100
    May 2015
    spring hill, FL
    40
    Test done at 830pm, 84
    CL - 5
    PH - 7.8
    FC - 3.5
    CC - .5
    TC - 4.0
    CH - 450
    TA - 130
    CYA - 50
    Looks like I need to lower the pH a bit, but otherwise, not too bad. No complaints, again I'm just grateful to have found this site. Keep up the good work guys and gals!!
    12k in ground, 14x28 sports pool, concrete/plaster/diamond brite, uncovered
    Waterway 1.5hp pump, waterway 150sqft cartridge filter, auto chlorinator, on city water, Zodiac MX8
    May 2015
    spring hill, FL
    40
    Re: First test with TF-100
    Might be a dumb question, but do you guys test with the filter running or with the water stationary?
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    looks like your TA and CH are higher than recommended, be sure to check out recommended levels in pool school under handy references. Oh and welcome aboard !
    You should have the pump running before drawing test water to make sure everything is mixed well. at least 30 minutes before should work.
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I run the pump for about 30 minutes before testing. If I add any chemicals, I leave it running for 30 minutes after the last addition.
    May 2015
    spring hill, FL
    40
    OK thanks. I'm going to drain and fill about 20% then retest.
