Thread: De back in pool
    Jun 2015
    Mastic beach
    3
    De back in pool
    Hello I have a 24 round above ground pool with a ec50 brand new DE filter and 1.5 Hayward pump the filter I installed this week I vacuumed the pool and disconnected the vacuum restarted the pump and two hours later what looks like brown DE is in middle of pool again last year I was told it was my filter so I replaced it what can
    It be please help
    38,472
    Re: De back in pool
    Welcome to TFP!!!
    What does your water look like?
    It could be be debris resettling after you stirred it up with the vacuum.
    What test kit are you using to balance your pool?
    Jun 2015
    Mastic beach
    3
    Re: De back in pool
    It's crystal clear I have my water tested from pool store and they say it's perfect it's so annoying
    38,472
    Re: De back in pool
    Well, we do not trust pool store testing and think it is worth what you pay for it.
    Recommend you invest in one of the Recommended Test Kits for the future.
    So what happens to this debris when you brush it?
    I assume you put the right amount of DE into the new filter and did not see DE spraying into the pool?
    Jun 2015
    Mastic beach
    3
    Re: De back in pool
    I did use correct amount of de when I sweep it moves around gets a little cloudy in that area and settles turn on filter it all goes back to middle vacuum it up its gone turn on filter it's back
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: De back in pool
    There are a couple of ways DE can get back to the pool from the DE filter, it can come out the returns thanks to a torn grid or finger (depending o n type of de filter you have), or it can backflow out the drain / skimmer when the pump is off if the check valve has gone bad.
