Results 1 to 16 of 16
Thread: loosing chlorine fast
    Jun 2015
    Beaver Falls PA
    7
    new to Trouble Free Pool.
    21 foot AG 52 Inches Deep.Chrystal Clear Water
    Hayward Pro Series Sand Filter Model S166T.Taylor Test Kit # k2006
    TEST RESULTS
    FC 1.5
    PH 7.8
    TA 120
    CH 180
    CYA 0
    Little about POOL 10 Years Old.New Liner Installed late Last Year . Filled With City Water.Did Not Use Much maybe 2 to 3 weeks then closed for season
    used pool store closing kit.
    38,274
    Re: loosing chlorine fast
    Welcome to TFP!!!
    If your CYA is 0, then you would lose all your FC to the sun in a few hours.
    What does the water look like now?
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome grayham!
    According to your numbers it sounds like the Sun is getting the FC. Bring it on up to 40-50 and see how that does for you.
    Essential Links:
    Jun 2015
    Beaver Falls PA
    7
    water is very clear
    38,274
    Did you have CYA in the fall?
    Was this a new fresh fill?
    Did you test the CC?
    Jun 2014
    15,091
    Hello Grayham! Kudos on doing your own tests with a proper test kit. I think we all see the same thing ... no CYA. It's like trying to keep coins in your pants pocket with a hole in it. Once you add some stabilizer in there as advised above, it will serve as sunscreen for your free chlorine (FC) and you'll see much better results. By the way ....... welcome to TFP!
    Jun 2015
    Beaver Falls PA
    7
    yes on cc test it was 0.50. and on cya last fall i did not know anything about it until i started to do my own testing this year.pool store installed new liner late last year.filled with city water.was told to shock once a week and check ph level
    i added bleach after dark tonight.i put to much in raised FC to 4.0 opps.
    Jun 2015
    Beaver Falls PA
    7
    I will be starting the cya process this saturday.what is best to use powder or liquid ? .starting at half of what poolmath said to do. then add a little as it starts to gain in ppm,s .
    Jun 2014
    15,091
    You can use either the granules or the liquid. The liquid is a bit quicker of course, but I think costs a little more. The granules have to be placed in a sock by your skimmer so it can be slowly dissolved and ingested into your skimmer.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    CYA granuales are by far less expensive than the liquid.
    Divin Dave,
    Jun 2015
    Beaver Falls PA
    7
    Thanks
    Jun 2015
    Beaver Falls PA
    7
    New test
    FC-3 , CC- 0.5 , PH- 7.8- 8.0 , TA- 120 , CH- 200-250 , CYA- 30-35 .
    Jun 2014
    15,091
    Those are much better numbers than before. Although you may want to bring that PH down a bit to your recommended 7.5-7.8 range. Don't let the FC drop below 3. After a few more days, check the CYA again. You don't need to check that every day.
    Jun 2015
    Beaver Falls PA
    7
    THANKS to TFP and all members for help. with TFP and group of good people and my taylor test kit i dont see the need to be running to pool store with water samples every other couple of days.i will continue to use TFP . I was told by my pappy every day you learn something new that was a good day !!! .
    Jun 2014
    15,091
    Amen to that! Stay in touch and post if you have any more questions.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Right on!
    Please add your pool info to your signature as shown here, Pool School - Read This BEFORE You Post
