How much rust is too much on wall above ground
Jun 4, 2015
2
Cincinnati Ohio
Uncovered our pool Memorial Day weekend to discover liner came off the bead.( bead had broken ) Removed the liner to replace and found rust on the walls. I'd say that 1/4 of wall surface is involved. Pool is 15 years old. Is it salvageable? Above ground pool - Trevi International
Welcome.
Post pics. Get a wire brush n,spray paint it with rustoleum paint.
The pool man came today and simply covered the walls with wall foam before installing the new liner. There were 2 little holes that he taped a piece of metal to cover them up. He then re-leveled the walls and adjusted the top rails. re-smoothed the sand and re-created the cove in the corners. He said I should get another 5 years out of it. I am happy that I have my pool back for awhile anyway.
