Thread: How much rust is too much on wall above ground
    Jun 2015
    Cincinnati Ohio
    2
    Uncovered our pool Memorial Day weekend to discover liner came off the bead.( bead had broken ) Removed the liner to replace and found rust on the walls. I'd say that 1/4 of wall surface is involved. Pool is 15 years old. Is it salvageable? Above ground pool - Trevi International
    Casey's Avatar
    SW PA
    10,423
    Re: How much rust is too much on wall above ground
    Welcome.
    Post pics. Get a wire brush n,spray paint it with rustoleum paint.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Only thing I'd add is I'd probably primer it first after sanding.
    Jun 2015
    Cincinnati Ohio
    2
    Quote Originally Posted by bkernan View Post
    The pool man came today and simply covered the walls with wall foam before installing the new liner. There were 2 little holes that he taped a piece of metal to cover them up. He then re-leveled the walls and adjusted the top rails. re-smoothed the sand and re-created the cove in the corners. He said I should get another 5 years out of it. I am happy that I have my pool back for awhile anyway.
    Jul 2014
    Oakbank, Canada
    389
    Excellent news.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
