Results 1 to 9 of 9
Thread: Teach me your chemistry!
    aSchoch's Avatar
    May 2015
    Plano
    7
    Ok, so I'm ditching the pool store and I'm going to need your help! My pool looks amazing after you all helped me through a nasty algae issue. I had the water tested assuming it would be perfect because it just looks SO pretty! Unfortunately, it isn't and they (of course) suggested that I purchase 4 different products to balance it. I know my first step is to purchase my own tester. Can y'all recommend one that is accurate and decently priced? Ok, for the chemistry...... here are the readings they came up with. I just did a huge dose of chlorine to kill the algae so why am I back down to zero?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Teach me your chemistry!
    Easy, here is the kit you want. Do not confuse cost with value. This is the best value out there for a test kit
    TFTestkits.net
    The chlorine question is easy, your pool consumes chlorine every day. You have to add it every day.
    The teaching is above this post under the link to Pool School.
    Oh, Welcome to TFP!
    Support the site
    aSchoch's Avatar
    May 2015
    Plano
    7
    Whoa, you add chlorine every day?! Wow! So then I need to just figure out the alkalinity and CYA issues. Ok, off to pool school I go!
    Jun 2014
    15,034
    Many of us have been in your shoes and you are making the best decision imaginable to test and maintain your own pool. I was ignorant of basic principles allowing the pool store to misguide me. With TFP, and my TF-100 test kit, my pool is crystal and requires very little effort to maintain. As you go through the TFP site and/or the links below in my sig, you'll begin to understand why it works....and what the pool stores do NOT tell you.
    Oh, and don't forget to update your "signature" located under you profile settings with your pool information. That comes-in quite handy. Welcome!
    May 2014
    Franklin, NC
    9,184
    Yup, to steal Richards line, a pool is like a pet - you have to feed it every day, even on days you don't want play with it.
    Support the site
    Orlando, FL
    690
    Yes, between bathers and sun, you will have to add chlorine frequently. Initially, it will likely be everyday. At this moment, you must add some or you are going to be fighting algae again. Use Pool School to figure out how much. Once you get it under control and start to understand the chemistry, you might be able to go two days but you will have to check it everyday. There are ways to add liquid chlorine of you desire but that is probably a bit in the future.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    BTW, according to their test your TA (total alkalinity) is perfect. Don't listen to their recommendations.
    That is assuming their test is correct, which it often is not.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Here is the first lesson.
    1. Dont listen to the pool store. Their adivce and testing is horrible.
    2. Get your own test kit and test the water yourself.
    While you are learning the chemistry (it takes a while to soak it all up), use these following 'tools' to maintain your water parameters. You will needing these from now on, so book mark them or print them out for quick reference.
    Pool School - Chlorine / CYA Chart
    http://www.troublefreepool.com/calc.html
    Divin Dave,
    Jan 2013
    The Colon(y), Tx
    47
    Welcome from a former PSHS Wildcat ('94)
    I'm now far...at the western end of Spring Creek Pky
    15k in-ground pool, plaster, Aquapure 1400 (whole new cell/cables/sensor 5/25/15), Pentaire Cartridge filter, Ruud heater(2/13), Polaris 360 pressure side cleaner (10/14), some other stuff...
