Results 1 to 16 of 16
Thread: Starting with BBB method
    May 2015
    Nacogdoches texas
    21
    A friend has a pool exactly like mine and is setting hers up using BBB method. We are both new to this so if you could help get us started that would be great. She does not have the SWG like mine does. She just drained and refilled it. Ph is 7.8 and there have been no chemicals added... So what do we do now?
    Intex 22'x52" above ground pool with cartridge filter and Intex SWG
    k2006 test kit
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Starting with BBB method
    got a TF-100? first thing you both need. add chlorine to keep algae at bay.
    as soon as you get the TF-100, run a complete set of tests and post them all here and you will get instructions on what to do next.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    38,284
    If the water is new, then you need to add 30ppm of stabilizer (CYA) and maintain adequate FC.
    Agree you both should have one of the Recommended Test Kits.
    May 2015
    Nacogdoches texas
    21
    I have the k2006 test kit. That's how I got ph was 7.8. When I added the scoops to test chlorine is did not turn pink at all. It is brand new fresh water.
    k2006 test kit
    38,284
    So there is no chlorine in it .... add 2ppm and get the CYA dissolving in a sock.
    May 2015
    Nacogdoches texas
    21
    I was going to add bleach but I don't know how much. I am trying to use the calculator on here and it is suggesting 83 oz of bleach. Does that sound right? The other Bs are borax and baking soda- do I add any of that?
    k2006 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    The pH is in range, and the stabilizer will push it down a bot, so it's fine.
    So, yeah, I concur with the others. Use poolmath to calculate how much 2 ppm FC is in that pool and add it. Expect it all be gone tomorrow. Calculate how much stabilizer she needs to get to 30-40 CYA and fill a sock and set that in the basket to dissolve. Tomorrow, add the same amount of bleach. By day three, aim a little higher on FC.
    Definitely get a test kit coming. There just ain't no way to maintain a pool our way without one.
    38,284
    Why would you add other products (whether or not they start with B is irrelevant and also why we do not use the BBB term any more) if the test results do not call for it?
    What volume did you set in PoolMath?
    What bleach strength?
    What target FC level?
    83oz sounds like way too much.
    May 2015
    Nacogdoches texas
    21
    I put 10000 gallons. I set the fc target at 4. But I changed it to 2 and it said add 42 oz of 6% bleach. And add the stabilizer. So I need at add this same amount of bleach everyday for 3 days? I'm sorry for my confusion this is my 1st year to do this on my own. Thank you all so much for your help!!!
    k2006 test kit
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by Donnapatton2005 View Post
    Yes. pretty much. With zero CYA, you target 2. The target doesn't go any higher until you pass the 30 mark on CYA, and the majority if not all of it should be dissolved in three days. When it's dissolved, just assume you reached the target CYA and adjust the target FC accordingly.
    38,284
    Probably closer to 11k gallons.
    You need to add the stabilizer (30ppm).
    And then daily (not just 3 days) test the FC and add enough bleach so that the FC never drops below the minimum for your CYA level. Once the CYA starts dissolving, assume the target level to get your required FC levels. See the FC/CYA Chart.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Also, check the bleach. Most household bleach is now 8.25% and 121 oz. So if you don't change it in poolmath you will over shoot a little.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    May 2015
    Nacogdoches texas
    21
    Thank you all!!!
    k2006 test kit
    May 2015
    Savannah, GA
    62
    I was new to pool math too. I had to go in and adjust all the settings to match my pool and the products I was using.
    Be sure to double check all your info.
    Sometimes my browser resets and I have to adjust it. Watch for changes when you open it up because mine defaults to 6% bleach at 96 ounce jugs often and I have to change it.
    Second be sure yo are putting in correct target numbers and now numbers. Once you play around you'll see it's super easy to use.
    -Amber
    24 ft round 52 in Evolution CLX 13,000 gal, Hayward S180T pump sand filter & 1 hp Power-flo Matrix single spd, TFP method, Borates Added, Taylor K-2006 Test Kit (Rincon/Savannah,GA)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP Donna,
    It's only intimidating and seemingly complicated at first. There will be a point very soon where you won't believe you thought it was at all. You'll get there soon, don't worry.
    Essential Links:
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    if you have the K2006, run a full battery of tests and post them here so you can get input on anything else that may be needed
    Dan
