Results 1 to 17 of 17
Thread: HTH Green to Blue granules
    Jun 2015
    Severn
    11
    I used the HTH shock green to blue granules, and its been 5 days and still cant get all the granules off the bottom of pool, its 28,000 gallons and pump is 2 speed pump and has been alternating between low speed and high for days, i cleaned oit the cartridge filters twice, they were pretty clogged, any suggestions, i also have been brushing the sediment towards floor drains, and pole vacuums, but still a lot left, any ideas
    26k pool,ingrnd,pebble,c4000bh,cartridge hayward cx875re(4),2speed hayward selfpriming,severn,md,usa
    38,521
    Re: HTH Green to Blue granules
    We do not recommend the use of products like that ... no idea why they are not dissolved.
    Why did you add that product? How does your water look?
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Jun 2015
    Severn
    11
    I am newbie, and bought it at Walmart, any suggestions on getting it out,water looks better, but the granules are at bottom,and looks bad
    38,521
    You have to scoop them out, brush them around to dissolve, or vacuum them up.
    What does "looks better" mean?
    If you want to clear up the pool and take control, you need to invest in one of the Recommended Test Kits and follow the ShockLevelAndMAINTAIN Process.
    Jun 2015
    Severn
    11
    I saved pool details to signature and city state,should be on there now
    Jun 2015
    Severn
    11
    Is it possible to run pump,without filters,and vacuum everything out
    Jun 2015
    Severn
    11
    it looks like drains are pulling it, but its coming right back out in the return
    Jun 2015
    Severn
    11
    filters after rinsing 2 days in a row, and i cleaned pretty good, just with hose
    Jun 2015
    Severn
    11
    Im getting ready to clean again, it seems the granule shock from the hth green to blie,is clogging it up bad
    30,432
    It appears you are trying to clear algae from your pool with filtration......not chlorine? Do you test your water? Can you post current test results?
    We can help you fix that pool but your first step will be providing us (and you) with adequate test results.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Dave is correct, filters will never fix a chemistry problem.
    You need one of our recommended test kits and to SLAM that pool. Stay out of pool stores as they will not be your salvation. Nor will miracle fix it potions. Lots of chlorine will clear that pool.
    Support the site
    Jun 2015
    Severn
    11
    I am going to order the reccomended test kit online, is there a reccomended place to buy one on the mean time, i cheap test strips for now, and shows the ph at normal 7.2, i added ph decreaser 2 nighrs ago, and it brought it down to good level, the bromine level is bad (is that chlorine) but the other levels looked normal
    Jun 2015
    Severn
    11
    The granules at the bottome of pool,is from the cheap hth shock qrape, i just cleaned filters and started vacuming, it got a lot more oit, but then it started shooting the same dust cloud back into pool inlets, i believe i found a backflush vlave to hook up a hose, before the filter and tommorrow vaccume out the granules to waste instead of through filter
    38,521
    Forget about the test strips. Just wait for the good test kit.
    You should not have any bromine in your pool ... that is a different sanitizing method.
    Jun 2015
    Severn
    11
    Ok, i will wait on the real kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    More info on cleaning your cartridges here, Re: How to clean a cartridge filter
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Howdy "neighbor". If you get your TF100 and follow the advice here to clear up your pool then your pool will have a beautiful sparkle and be properly sanitized. It can take some work to get it all cleaned up but the reward is well worth it and cheaper to maintain than going to pool stores. I hope you follow the advice here.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
