Thread: Raypak P-M336A-EN-C flame issue!
    Aug 2014
    Middletown/NJ
    3
    I recently replaced the control board to fix an ignition problem. It worked but, There's a flame coming out from the tray up the inter side of the access opening.
    Is this caused by a hole in the gas header feeding the burners? It's on the right corner (facing the unit), just above the pilot (not the pilot).
    This heater is 3 years old and not rusted, although it does look like the weld joints holding the header to the bracket (still on the right hand side) may have pulled off the header. ***, how does that happen?? Not so good luck with this heater.
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: Raypak P-M336A-EN-C flame issue!
    Can you post a picture of this issue?
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
