Thread: Where does this pipe go
    Jun 2015
    Severn
    11
    I know the right pipes and left pipe,they are labeled, skimmer,floor drain ,and return to pool, but the middle pipe is not labeled, what or where do u think this goes, i turned the valve,closing line to filter and opening line to this, and pipe seemed to jump out of ground a like it was a lot of pressure or clogged.
    26k pool,ingrnd,pebble,c4000bh,cartridge hayward cx875re(4),2speed hayward selfpriming,severn,md,usa
    38,524
    Re: Where does this pipe go
    Welcome to TFP!!!
    No way for us to know. Many possible options:
    1. Water feature in pool
    2. Pressure cleaner line (although usually after the filter)
    3. Waste line to drain water (either to sewer or some other drainage place)
    My guess is waste line
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Since it diverts water away from the filter, Im guessing waster line too
    Divin Dave,
