Results 1 to 9 of 9
Thread: What is this thing called?
    Mar 2015
    Harvey, LA
    300
    The plaster crew is coming today to spray the pool, and since the pool is empty and prepped, I am taking the opportunity to replace all of the jet nozzles and removable fittings with brand new stuff (the previous owner let the water balance go out of hand and stained a lot of the plumbing). I've got everything else, but I can't figure out what this item is called so I can get one. It sits about a foot and a half below the skimmer, and seems to have some light suction to it. I was told by one of the service crews that it is for if the water level gets below the skimmer to stop the pump from sucking air...
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Mar 2015
    Harvey, LA
    300
    Re: What is this thing called?
    Here are pics:
    38,449
    Since it is below the skimmer, I am going to guess that is an equalizer line running to the skimmer. And that is just a grate to keep large objects from being sucked in ... although water should never really be sucked in through that hole unless you let the water level drop way too much.
    You really do not need to have anything there IMO.
    Adjust the float diverter under the skimmer basket so you do not have a lot (if any) suction through there.
    Mar 2015
    Harvey, LA
    300
    Sorry, I guess I'm not being clear...I want to replace this item, and want to know what the fitting is called, so I can order one. I googled for pool grate, and didn't find anything like it. There are two in the pool, and one is broken (demo crew accidentally busted it while removing the plaster).
    38,449
    I have no idea what you would call that. First time I have ever seen one
    Well, took me 5 seconds to find one:
    http://www.poolsupplyunlimited.com/AquaStar15SafetyGrateInsertwith15MPTDarkGrayCFM105/141118p1
    Mar 2015
    Harvey, LA
    300
    AquaStar 1.5 MPT Dark Gray | CFM105
    Should I be concerned that the description from your link says "Not to be used as a suction outlet under any circumstances"
    38,449
    It says that because it is not designed to prevent entrapment.
    But as I previously stated, there should not be any suction through this line unless you have a problem which should be pretty apparent based on the water level. Usually there is no cover at all on these equalizer lines.
    Mar 2015
    Harvey, LA
    300
    I originally thought these were dedicated vacuum ports, but when I put a hand down there, there was so little suction that it was hard to tell if any was there at all...so I think they're fine. This is more an exercise is aesthetics here. Thanks Jason!
    38,449
    Make sure the flap on the float diverter under the skimmer basket is completely open so that nearly all the flow is through the skimmer.
    Well, looks like there are a lot of colors available, so you can match what ever you want.
