Replacement pump recommendation
jmastron
509
Sacramento, CA
Okay, I was putting this off, but our pump is grinding louder and louder by the day, to the point that it’s uncomfortable to be in the pool area when it’s on, and I’m just waiting for the neighbors to complain. Whether it’s on its last legs or not, I think its time is up, so I’m deciding what to replace it with.
Current pump is single speed 3/4hp, manufactured in 2005 (we bought the place last summer), on a ~22k gallon pool in a climate where we don’t really close (but only swim Apr-Oct, and I cut the pump time back significantly over the winter last year). No solar or SWCG currently, but I’m considering both in the near future. Our marginal electricity rate is about $0.19/kWh, but it’s not all about payback time; I’m willing to pay more for quiet and flexibility for future uses also. Given the age of the equipment, I don’t believe just replacing the motor is a good idea.
The options I’m looking at (with approximate pricing, assuming I buy online and install myself):
1) Pentair IntelliFlo VS 011018 (~$850). Honestly this is what I’m leaning toward, despite the cost.
2) Pentair SuperFlo VS 342001 with built in controller (~$650)
3) Pentair WhisperFlo 2-speed, 3/4hp or 1hp (~$540)
4) Pentair SuperFlo 2-speed, 1hp (~$420)
5) Pentair SuperFlo 3/4hp 1-speed (~$275), as a baseline replacement comparison.
I know conventional wisdom here is that 2-speed is sufficient at lower electric rates, and we’re probably borderline, but I’m really leaning toward a VS pump for a couple reasons: No need to replace the old mechanical timer with something that can control 2 speeds ($200 right there); potential to add solar fairly that will be 40-50 feet horizontally and 8-15 feet vertically away; with the unknowns of our archaic old plumbing (1-1.5” copper piping, single skimmer and 2 closely spaced returns off the same pipe) it seems more likely to be able to tune the sweet spot of filtering, skimming power, noise, etc, if I can try various speeds. Am I thinking about that correctly?
Between the SuperFlo VS and IntelliFlo VS, since I have no need for the extra HP of the IntelliFlo, it seems the main differentiator is the control systems -- the built in controls are similar (3 vs 4 speeds, but both have a timed “quick clean” for putting in chemicals), but connecting to other equipment is very different -- the SuperFlo seems to just be switching wires to trigger the preset speeds, while the IntelliFlo allows an EasyTouch (which I plan to install in the future) to fully control and get feedback.
Am I missing anything? Any other suggestions or recommendations?
If you are planning on automation and want the flexibility and your power is expensive, then a VS makes sense. The Intelliflo is certainly overkill in terms of size, but would integrate into automation better.
Although I thought there was a newer version of the Superflo VS that does integrate with a communication wire into the automation.
BTW, the sound is really more related to the speed you run the pump. a 2-speed on low is very quiet. And a VS at high speed is going to sound similar to a 1 speed or 2-speed on high.
Yes, sort of...best I can tell from the Pentair site and manuals (which are pretty bad in some areas!), each of the VS pumps has weirdly non-overlapping control possibilities:
SuperFlo VS 342000
- Simple built in controller -- no LCD display, but does seem to allow setting speeds and durations to follow a 24 hour pattern, though if power is lost it starts the sequence whenever power returns.
- Appears to have a serial communication port with 12V/A/B/Com, but there’s no further mention or documentation on this; could this connect to EasyTouch etc?
[EDIT -- Pentair response on another site indicates this pump does NOT have RS485 connectivity]
- Individual low voltage automation terminals to select each of 3 speeds or override. Good for simple automation (remote switches, low voltage timers, etc)
SuperFlo VS 342001
- Better built in controller -- LCD that shows speed and watts, set scheduled based on time of day. Retains time and schedule during power failure.
- No serial communication port, at least not mentioned in manual's wiring section; I’m not sure why it wouldn’t have something that the 342000 has?
- Individual low voltage automation connections to select speeds and clean override -- but requires a special connector/cable that I can’t seem to find the availability or price of anywhere.
- Best built in controller -- similar to 342001 with more speeds and features.
- Serial communication RS485 connection, with documented support from EasyTouch etc controllers
- Requires IntelliComm adapter (~$200) to break out individual speed controls
So each seem to have their own connectivity pros and cons, and since I’m doing this in the wrong order (buying pump now, potential automation later) it’s hard to decide which is best. For example, connecting a relay to the Polaris booster timer that makes sure the main pump is on would be trivial with the 342000 (dedicated terminal), a bit harder with the 342001 (need the special cable), and requires a $200 box with the 011018. Hmmm…
Hopefully all will be quieter than my failing vibration grinder, er, pump :) But agree, that's what I'm thinking -- if the equivalent of a 2-speed's low isn't quite enough to filter while we're in the pool, with a VS I can tune a higher speed that's still not as noisy as the 2-speed's high.
It will definitely be way quieter. I love my intelliflo 3hp VSpump. It is more pump than I need but it does everything I ask it to do. You've got the right idea. No timer, my pump is wired direct to the breaker.
After some trial and error I got mine all dialed in as follows,
Skimmers and SWG at 1100 rpm, 150 watts
Solartouch bumps the speed to 1950 rpm, 550 watts
Brush pool to bottom drains 2500 rpm
Skimmers and waterfall 1500 rpm
I will definitely get another one when the time comes. You can see that I never get close to max rpm of 3450.
Thanks for all the inputs!
Further research finds a response from Pentair on a forum about a year ago stating that the SuperFlo does NOT have RS485 capability, despite the terminals listed in the manual (presumably that's referring to the 342000, as 342001 wasn't out yet). At some point, I might be willing to write a Pool School/Wiki entry on pumps/automation capabilities if such doesn't exist.
I am leaning toward splurging on the IntelliFlo VS -- yeah, I may be overspending, but should do everything we ever need and it gives the most flexibility for later automation (either direct RS485 or with the IntelliComm for simpler control). I'll offset the extra cost with my obsessive search for the cheapest chlorine to save $1/week :)
It's too bad the pump's built in controller doesn't have an aux output or two that could be triggered with one of the speed settings that could be used to control boosters, SWCGs etc. But then they wouldn't sell as many automation systems I suppose.
Anyway, planning to order this afternoon, so any last minute thoughts are welcome!
Re: Replacement pump recommendation -- Installation Questions
The next set of questions is about pump installation, not selection; not sure if I should use the same thread or start a new one, so starting here.
I have the IntelliFlo VS coming today, and have some questions on installation:
1) Virtually all of my pool plumbing is 1.5”, including the copper suction and return lines underground. I’m going to be replumbing a bit of the aboveground parts, but is there any real advantage to using 2” for the 5-10’ total (including the whole loop to and from pump and filter back to the ground) when the other 30-40’ in the system are 1.5”? It’s a bit more convenient to transition to 1.5” at the union slip side and use that. If it helps I’m replacing a 3/4hp pump and plan to limit the VS to similar flow rates as that one achieved (and slower, of course)
2) I got a set of unions (threaded to slip); they have gaskets both in the union connection itself and on the threaded connection. So, do I still use thread sealant or tape, or rely on the gasket as the primary seal?
3) The manual recommends 5x the pipe diameter as straight pipe into the inlet (i.e. 7.5” for 1.5” piping, 10” for 2” piping). However, where the suction pipe comes into the pad and where the pump can sit means either a much shorter distance (1” at most), or having the return come up, turn and go the wrong way, then U turn into a longer straight pipe into the pump. I can take a picture if that’s not clear. Since it also says “plumbing on the suction side should be as short as possible”, which way should I do this?
4) For baseline speed setting and comparison, am I thinking correctly that if I adjust the VS speed until the filter pressure is the same as it is on the current pump, that I’m getting a roughly similar flow rate? I’m thinking of installing a flow meter, but won’t have that in time to get a measurement with the old pump.
5) Anybody have any idea what the heck these pipes are? They come off the return line (the pipe out of the filter Tees to each of these, then around to the actual return line). Both have PVC valves that are off, and clamp onto what looks like ½ to ¾ flexible PVC disappearing at an angle into the pad. There are no additional holes in the pool that I can find, so I can only guess these were old return lines that leaked/have been abandoned (but were extended when the pad was redone?) The pool was built around 1960, and from the concrete patches it looks like the current main return was added in the 70s (guessing because it’s copper into the ground). Any other thoughts on where these might go? I want to reroute the return pipe and cut/cap these off closer to the ground, so the new pump can sit in a better place for the controls. And I’m afraid to try to open the valves to see what happens, for fear they’ll blast holes in the side of the pool :)
Thanks for all the advice.
1) Using 2" for all the pad plumbing is worth it because the turns can add up to a fair bit of head loss. The turns add more head loss than a bunch of straight pipe and by going up to 2" for the very little increase in cost is worth it IMO ... especially with a VS pump where you may be able to run a little slower and have adequate flow rates.
2) Not sure ... have no seen a gasket in a PVC threaded fitting.
3) Usually the distance does not matter, but there have been a few cases where people have shown issues when trying to run at high speeds with a short section in front of the pump. Hard to say .... you would have to add 2 additional 90 turns to the suction line based on what I see in your pic ... unless you completely redesign everything.
4) No. You want to run as slow as you can and still have everything working ... based on your sig, looks like the skimming action is your only flow rate concern. Try 1000 rpm (most efficient speed) and increase as required.
5) No idea ... I would turn them on and see :D
That makes sense. I will transition to 2” close to where the suction and return lines come out, and redo everything else as 2"
The unions look like this: http://ep.yimg.com/ay/yhst-47220742460910/custom-molded-products-2-hi-temperature-union-pump-adaptor-21063-200-3.gif
You can see the gasket at the end of the threads. I guess since it’s a union I can try it with just the gasket, and if it leaks take it out and add sealant!
I think I’m going to do the U-turn thing, because it allows the pump to be in a more convenient position (rotated to the left so the controller is accessible). I will use 2” elbows and pipe.
Right; I know I want to run much slower normally. I just want to see out of curiosity what RPM (and power consumption) corresponds to the current screaming beast.
As you mention, skimming is an issue -- only have 1 skimmer that makes all the pool guys go “huh?” -- 13” wide and deep with a weird shallow basket and a jury-rigged weir door (currently 10” with tiles wedged in as spacers). It feels like a lot of the surface stuff doesn’t get pulled in. I might try running at a faster speed for an hour a day to get better skim, then slow it down to circulate; I’m very excited about the tweaking possibilities the VS pump allows!
It just hit me -- there must have been solar at one point! That would explain the valve between the tees. Or possibly a heater, but don’t know why they would go underground, and I can’t think of anything else that would be away from the pad and bypass the return line like that. I wonder where they go; it’s the opposite direction to the house. There is a shade structure with a flat roof next to the other side of the pool, must be there. Now I will have to turn one on and see where water comes gushing out :)
Thanks for all the input!
Interesting on that union fitting ... you should not need any sealant. But, I am not sure where that is meant to be used. Is it to attach to a filter? PVC threaded fittings are tapered and with an O-ring, the threads are not usually tapered.
Well, if it is solar, it is not a very efficient system given those really small tubes.
