I don't think the disinfection by-products that are causing the coughing are just trichloramine. They would be so low as to generally not measure on the CC test. The high CC that correlates with the coughing may indicate precursors, but the products may be other items (see this link).
This link does provide hope for UV getting rid of chloramines.
It is true that trichloramine is very volatile so can easily be removed from water through spraying and air exchange, but that can be a slow and energy-inefficient process if the fresh air outside is cool. It isn't much different than just providing greater air circulation in the indoor pool area except that one can concentrate the volatile chemical removal and cooling to the water itself rather than the bulk air in the room.
Remember, though, that this pool isn't heavily used. There is something strange about this particular situation. It's as if something was added to the pool that is a prodigious precursor to chlorinated disinfection by-products. The combined chlorine is fairly persistent so probably not inorganic chloramines. This just doesn't seem like something from low-bather load.
I, too, am hopeful that the UV system resolved this problem.
Richard
Richard
