Results 1 to 8 of 8
Thread: pool opening : how muxh chlorine to add if cya is unknown??
    I'm ground pool has been closed all winter. I'm going to be opening soon but how much chlorine do I add if I don't know the cya? Doesn't the pump have to be running for a certain amount of time before I can't test for cya
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pool opening : how muxh chlorine to add if cya is unknown??
    You can test for CYA now. It won't settle out.
    Jun 2014
    15,233
    I would definitely check that CYA now so you can get started. Do you have your own (TFP-recommended) test kit to check CYA? Feel free to post all of your numbers so others can review and assist as needed if you would like.
    Busy the water has been sitting for so long? I guess I ll take a sample and goto pool store. ( even tho I don't wanna put my arm in that gross water lol)
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    38,489
    Sounds like you first step needs to be investing in one of the Recommended Test Kits ... having the pool store test your water is a sure fire way to spend $ and not make progress.
    Ok so water doesn't need to be mixed to test for cya?
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    38,489
    Ideally it should be since the upper water may be from rain/snow and not mixed.
    Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    We have had members have CYA tests from pool stores be off by more than 100ppm. It really is better to get one of the Recommended Test Kits
