Thread: units of measure
    May 2015
    Arab, AL.
    7
    units of measure
    in pool math when checking salt, are the units of measure "ppm"? the test strips use 2 different measurements
    20x40 in ground pool 9ft deep end vinyl liner with sand filter, salt system
    Jun 2011
    Long Beach, CA
    2,786
    Re: units of measure
    Yes, if you measure 3000ppm of salt enter 3000 in the salt column.
