Results 1 to 7 of 7
Thread: Total Alkalinity
    May 2015
    Oxford, Oh
    8
    Total Alkalinity
    Just had our pool installed. AG 18x33x54"
    Just finished the fill and started running the pump and the chlorine they gave me. My chlorine levels are about 2ppm. PH is in the "green" on the bottle of test strips they gave me. Everything is in the "green" aside from TA. I have my test kit arriving today. TF-100 however I'm curious about the TA, should I worry about that right now or let the water and pump run for a few weeks and see if it comes down on its on? I figured the high TA is from it coming from the tap. I will post more accurate readings this evening when I get home with my new fancy test kit.
    Thanks!
    18K gal, 18x33x54" AG, 1.5 HP Waterway Ecco, 200 sqft cartridge filter, Mizermax Pac Chlorinator, Kontiki2 Automatic cleaner
    Installed 5/30/15
    30,432
    Re: Total Alkalinity
    Post up your new readings before adjusting. TA has a fairly large margin of acceptability so let's see where you are.
    Don't want to get too far ahead of you but running through all the tests and posting your results will give you good practice and give us an accurate snapshot of your water.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Glad your TF 100 will arrive today. I agree with Duraleigh. One you test post a full set of results and tell us what your pool water looks like and we can go from there.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Oxford, Oh
    8
    Got all of my test results finally. Here we go.
    FC-6
    CC-1
    TA-280
    Total chlorine - 5ppm
    Ph- 7.2
    CYA-25 (right in between the 20 and 30 mark on the cylinder)
    Installed 5/30/15
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You stole my TA...lol just kidding I have a 230 TA on my well water and a 280 TA on my municipal water.
    Pool School - Lower Total Alkalinity
    It is a slow process. Here is the link to me bringing down my TA.
    Results after SLAM
    Your CYA is a little low. You can bump that to 30-50 range since you don't have a SWG. You add Stablizer wo a sock and set it in the top of the skimmer or hang it in front of the return with filter pump running. You cand squeeze it to help it disolve. Remember it won't show up for 1 week so wait a week to test it again after you add Stablizer. You can use pool math for calculations.
    CC may go away with sunlight since you just got the pool filled not sure that your really need to SLAM to bring it down. I am sure someone else will chime in.
    Lisa
    May 2015
    Oxford, Oh
    8
    It just says acid to lower it. What kind of acid?
    I really just want it safe for my daughter to swim in. She is almost 10 months. If it were just my wife and me then I probably wouldn't worry about the TA unless it started causing an issue with the PH or the calcium scaling.
    Installed 5/30/15
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Muratic acid. You can get 31.45% at Lowes and maybe the pool store. You cand get the 14.5% pool MA at Home Depot but you have to add more. You can swim 15-30 mins after adding MA.
    You will likely see your PH rise quickly with the high TA. Make sure you check PH daily along with FC. Run the other tests weekly.
    Lisa
