Thread: pool walls/floor very slimy/oily feeling
    Jul 2014
    Evansville, IN
    19
    First time in this year, and found the walls and floor of pool are very slick. Slimy/oily feeling. After rubbing hands across the walls, they are kind of tacky feeling.
    FC = 5
    Ph = 7.2
    TA = 70
    CH = 375
    CYA = 75
    Salt = 3800
    Temp = 85
    Water is clear.
    I haven't been scrubbing the pool walls/floor at all, maybe once since opening back in mid May.
    When opening, there was a bunch of slimy looking stuff in the skimmer area, of course it went everywhere after taking the cover off the opening.
    Thanks.
    18,000 gallon IG Fiberglass pool
    Sand filter
    SWG - Pentair IC20
    Pentair 1hp SF-N1-1A pump
    Raypak HP
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: pool walls/floor very slimy/oily feeling
    Given that your CYA is 75 ppm, an FC of 5 is just below what we recommend as the minimum for that CYA level. The slimy feeling is an early indicator of a nascent algae bloom. I would take the high road and SLAM the pool. BTW, you do have a FAS-DPD chlorine test right? You will need it for the SLAM along with lots of bleach.
    Jul 2014
    Evansville, IN
    19
    I do have the TF100 test kit.
    Thanks for the advice.
    Sand filter
    SWG - Pentair IC20
    Raypak HP
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Quote Originally Posted by BoDarville View Post
    ??? A FC of 5 is right where it should be for a SWG pool with a CYA of 75 correct? I am thinking that he did not notice you were SWG...
    Regardless, if it is slimy it has some algae, so a SLAM is in order.
    Now get scrubbing!
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
