Thread: What is this part?
    Jun 2015
    Bend,OR
    3
    What is this part?
    Been having issues for weeks with sand in the pool (45,000 ish) new Pentair triton 2 filter. Popped the cover off tonight and found this on top of the sand. Is it part of the filter?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: What is this part?
    That appears to be the screen that goes on the air relief hose. There should be a hose in there to let the air out of the filter automatically instead of having to open a valve on top of the filter to purge the air. That screen keeps the hose from getting plugged up.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2015
    Bend,OR
    3
    Thanks. Will that cause problems with sand in the pool?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Without it sand could get pulled through the hose and back to the pool. The hose could also get plugged up and have to be cleaned out or replaced which would require removing the sand to get to where it attaches.
    22,542
    That's an aerator intake strainer! Oh wait, we're not on the boat forum are we!
    As said above it's the air relief strainer. It's #8 in this parts breakdown.
