Thread: sand in pool
    Jun 2015
    Mt Zion, Il
    1
    sand in pool
    I was using a bag of sand to weigh down my ladder and it broke open. I talked to my pool dealer and he said to just vacuum it to waste. I vacuumed it up to waste and then went to put the filter back to filter. The valve would barely turn- you could feel sand in it. Then I noticed the strainer basket and pump basket were full of sand. I cleaned all that out and backwashed the filter, Then I was testing the valve and put in it recirculate for about 30 seconds to see how the valve felt.(not sure why I did this, but I did). then I put it to rinse and then to filter. Everything looked and sounded fine. Now several hours later the system is making a loud noise. I turned off the pump since it is night out and too dark to work on it. The pump was still moving water- it was just making a loud noise. I am guessing I have sand in my heater?? or somewhere that is causing pressure buildup. Any advice on where to start. If it is in the heater-how can I clean that?
    Help!
    Julie
    21' above ground
    minimax 100 heater
    sand filter with pump
    Oct 2007
    Cedar Hill, TN
    252
    Re: sand in pool
    Sorry about your pump problems, I can not help you with that.
    But for your next time to weigh down your steps, ...
    I have bleach bottles filled with rocks and bleach water under my steps. Also some PVC pipes filled with concrete and capped on both sides.
    No busted sand bags for me!!!
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
