Thread: DIY Stir plate question
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    I am building a DIY stir plate rather than buying a speed stir. Why? I need it for homebrewing as well, and need a larger stir bar and probably more power than a speed stir will provide.
    I read somewhere that the replacement stir bars to buy for the TF-100 are 1". The sample container is only about 1 1/8" ID. Seems pretty close for comfort. Is this correct?
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,768
    Re: DIY Stir plate question
    Yep. 25mm X 8 mm is the standard size for the speedstir. It's got a lip that centers the vials.
    22,373
    There's not much room in the vial with the standard magnet. You can find magnetic stirrers for less than $70 on Amazon or EBay.
    I love the speed stir, but it's not a true stirrer as it doesn't have a spinning head to rotate the bar. It uses an array of three stationary electromagnets that cycle around to cause the bar to follow.
    I have an Apollo stirrer that has a rotating magnetic head that will spin a pretty large bar or cross and cause a tornado vortex in a pretty large beaker.
