Results 1 to 11 of 11
Thread: Check out my filters!!
    Apr 2013
    Apple Valley, CA (high desert)
    15
    Angry Check out my filters!!
    So, last weekend my pump started running a little rough. It was having a hard time building and keeping pressure and just didn't sound right. After letting it run for a little while, I decided it would be a good idea to shut it down and check my filters. Mind you, the pump pressure never went up. I check it religiously when I'm out back and it's running. It never rose even close to 10% higher than the clean pressure. Anyway, imagine my surprise when I opened it up and this is what all four filters looked like!
    I was pretty ****** at myself for not checking these sooner, but I just went to work and cleaned them all up. Here is the after picture of what they all looked like after I was finished.
    Luckily, everything seems to be running fine after the cleanup. I'm now scheduling myself to check the filters at least once every two weeks for a while to make sure this doesn't happen again. We have crazy winds where I live and my house is on top of a hill, so we get a wind tunnel going every time. No surprise that this much **** would blow into my pool. I'm glad I got lucky this time, but I don't want to tempt fate again.
    20x40 ft. IG plaster pool, 26,850 Gallons, chlorine, Jandy Stealth Pro Series pump, Clear O3 ozonator, Nature2 Fusion, cartridge filter
    Rock slide/waterfall, raised spa with spillway into pool, 6x40 ft reef that's 18-inches deep, 30,000 BTU heater, TF-100 test kit to check it all
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Re: Check out my filters!!
    I can't see your pics. Is it just me?
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Apr 2013
    15
    If you click on them, they are there. I just didn't host them on a picture site, then post the embed link. Sorry about that.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    No attachments come up.
    Upload your pics to photobucket and then copy the IMG code for each image and plaste it in here.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by Azgirl71 View Post
    +1
    I get "invalid attachment" error when I click on the links.
    Apr 2013
    15
    All fixed now!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Wow! Definitely need to keep up on the filter. Nice job cleaning.
    Lisa
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Eee-gads! I liked it better when I couldn't see the images. Holy crapped-up filter cartridges, Batman!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I suspect you may have a bad pressure gauge
    Apr 2013
    15
    Yeah, I'm keeping a closer eye on it now and I'm going to get it replaced if needed.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Tftestkits.net have a very nice pressure gauge for like 11 bucks. Mmm, tasty filter treats!
