Results 1 to 8 of 8
Thread: Cover or not
    Jan 2015
    Puyallup, WA
    50
    Cover or not
    We have a blue solar cover and need to know the do's and dont's. For instance here In the NW we are going to have weather in the 80's for the next week so do I un cover during the day and cover at night or leave it covered unless we are using the pool.
    Thanks
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Cover or not
    It depends on how warm you want the water to get. If you like really warm water, I would leave the cover on as much as you can during the day. Just note that you will need to take it off at some point during the day or early evening to let the pump run, test chlorine, and top-off with chlorine as needed. Leaving the cover on at night will help retain much of the heat gained during the day.
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Re: Cover or not
    For me, I take my cover off when we have a bright sunny day and little wind. On cool overcast days and when we have lots of wind I leave it on. I always put it on at night regardless off the weather. I don't remove the cover when the pump runs or if I need to add bleach if it is already on.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    Re: Cover or not
    i take it off when i have sun and hot and when it's a cool, cloudy day i leave it on, but i definitely cover up at night.
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
    Jul 2012
    Chicago, IL
    356
    Re: Cover or not
    I leave mine on almost all day all the time except when swimming. The biggest key is leaving it on at night, that will give you the most help in increasing temps through reduction in overnight heat loss.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Jul 2014
    Sacramento, CA
    241
    Re: Cover or not
    My limited experience:
    - Nighttime: Cover on always; this is when it really adds value reducing heat loss.
    - Daytime cool or windy: Cover on probably better
    - Daytime warm calm and sunny: Cover off probably better for heat gain, but I think it's pretty close
    Having said that, I don't bother taking our cover off most days when we're not going to use the pool, even if it's sunny. No issues here with the pump running or the Polaris 280 working under the cover. I flip back one corner near the return when I'm adding chemicals or water.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Sep 2013
    Nashville, TN
    382
    Re: Cover or not
    Our water temp would drop 6-8* overnight without but only about 2* with the cover on.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Orlando, FL
    690
    Re: Cover or not
    I leave mine on all the time unless we are swimming. Even with it cut in strips, I get zero joy from removing it when we are not using the pool. At night is critical to keep from losing too much heat. With it on, I still lose 2-4 degrees depending on the air temp.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
