Results 1 to 7 of 7
Thread: Intex SWG low flow alert
    Jun 2015
    Elgin
    4
    I have changed filters, cleaned the little flapper in the intake side of my Krystal Clear SWG system, and even hooked up another pump to the pool. I have water flow like a fire hose, and the SWG still beeps and shuts down after about 20 seconds with a low flow signal. Does anyone have any ideas on why I would have this problem when I have sufficient water flow.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,424
    Re: Intex SWG low flow alert
    Hi, welcome to TFP! First make sure the cylinder is connected so the flow of water from the pump pushes the flapper open. I believe there are arrows molded into the cylinder to show the flow of water. Those arrows should point in the same direction as the flow of water into the pool. How long have you had this unit?
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Usually mine did that when the cell needed to be cleaned. Use diluted muriatic acid or vinegar.
    Jun 2015
    Elgin
    4
    Thanks for responding zea3. I used the same system last year and it worked fine. It is connected the right way which is what made this puzzling to me.
    How do I clean the cell with vinegar?
    Above ground 36"x16' Intex with Intex Krystal Clear SWG system
    DFW, TX
    24,513
    It came with a cap to close off one end of the cell, remove the cell, cap it, fill with vinegar and let it dissolve any build up, rinse, repeat until clean.
    Jun 2015
    Elgin
    4
    Thanks pooldv, I appreciate the info. I will post my results.
    Jun 2015
    Elgin
    4
    This is the first time my computer would let me log back on this site. I filled my SWG with vinegar and let it soak for a day. I reconnected it to the pool, and still have the same results. It will run and produce for about 20-30sec and then quits and displays low flow. Should I pull the ceramic looking thing out and brush it with vinegar?
