Results 1 to 7 of 7
Thread: White rubbery buildup at waterline?
    May 2015
    Arkansas
    15
    Our pool build just wrapped up about 3 weeks ago. I got in tonight for the first time and noticed a white buildup on the waterline tiles. It had a rubbery feel and came off fairly easily when I rubbed it with my fingers. What was it? Calcium?
    8000 gallon, finished 6/15, IG, Plaster (Diamond Brite Midnight Blue), Sand Filter, Pentair, HTH 6 way test kit, SWG, filled with city water
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: White rubbery buildup at waterline?
    My guess is calcium build up. However, I have never seen it rubbery.
    Do you have a recommended test kit yet? If so please post a full set of numbers.
    If you could also go to settings and update your signature with your pool and equipment info that would be great.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Arkansas
    15
    Okay. I'll do that. I don't have a recommended test kit yet. I need to order one this week.
    Mar 2015
    South
    18
    I had the same time thing with mine. I'm not sure what it was, but I will try to ask my PB.
    16x24 shotcrete pool with plaster; ~ 11,000 gallons; Hayward MaxFlo XL 1 hp pump; Hayward Pro-Series Top Mount Sand Filter; Hayward Turbocell SWG; Hayward ColorLogic LED light; Hayward AquaPlus Automation Panel; TF 100 Kit
    May 2015
    Arkansas
    15
    Quote Originally Posted by Aloha76 View Post
    Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Could it possibly be pollen? Are the window sills, patio furniture or parked cars covered with it?
    May 2015
    Arkansas
    15
    I don't think so. It wasn't yellow at all. I'm in Arkansas and the pollen had mostly all fallen before we finished thr pool. I should have taken pics. If I see it again, I will.
