Thread: New to TFP
    Jun 2015
    White Plains
    2
    New to TFP
    Renting a house with a pool and opened to a green mess.....read this forum first (thank god).
    I don't have the good test kit yet - have it ordered. But was a nice shade of emerald green and I know there are leaves under there some where! Just can see them yet, have scooped out as much as we could without seeing whats going on.
    I have added the Stabilizer and liquid shock. Had to backwash every hour so moved to recirculate for 2 days - water is blue but cloudy. Back washed and moved to filter for 2 days. I think I am on the right track.
    Readings with kit I have are as follows:
    FC - 5
    PH - 7.5
    TA - 120
    CYA - 20
    What's next???
    Thanks in advance!
    Stacey
    33,000 / IG / Vinyl / Sand / Hayward Pro Series S210T / Jacuzzi Magnum Force
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New to TFP
    Welcome to TFP!
    If you have already ordered the kit, I would maintain the status-quo until it arrives which should be in a matter of a couple of days . In the meantime, I would remove as much debris from the pool as you can and stock up on plain, unscented liquid bleach without any added thickeners. You will need it for the SLAM - a process you will start once your new test kit arrives.
    When your test kit arrives, take a full suite of tests and post them here and we will get you started.
    Jun 2015
    White Plains
    2
    Re: New to TFP
    Thank you!!!
    Stacey
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New to TFP
    You're very welcome. We help you get that pool cleared up!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: New to TFP
    Welcome!
    Pictures would be nice. If you do a good job going from a swamp to an inviting oasis, you could end up in my Inspirational Links thread.
