Hi Everyone. I have learned a lot about maintaining my new pool by reading the forums the last few months, and I would like to thank you for sharing your knowledge.
Now I have an issue that I haven't seen addressed. I have an Aqua Rite SWCG that is giving me accurate salt level readings of 3100ppm on the instant read display. I ordered the Taylor test kit to confirm this.
It is my understanding that the main salt level display is an average of the instant readings. It appears that the unit is taking instant readings even when my pump is not running, (pump currently runs 6 hours/day) therefore a lot of zero readings are being included in the average. This drives down my average reading below the lower threshold, the error lights come on, and the unit does not generate chlorine when the pump comes back on. While the pump is running, the unit will take correct readings and the average starts to come up again. It just doesn't get high enough for the unit to begin generating chlorine.
If I manually turn the Aqua Rite off when the pump is not running, the main display reading does not go down over a period of time.
If the flow switch is working correctly, should it shut down the unit so that it does not take readings when the pump is off, or is that a function of the unit being wired to the load side of the filter pump timer?
Some other information regarding the pool:
IG Fiberglass 11000gal
Temp 75-80
FC=5.0
CC=0
PH=7.6
TA=90
CH=240
CYA=50
Tested w/ Taylor K-2006 kit.
Thanks.
tl
Temp 75-80
FC=5.0
CC=0
PH=7.6
TA=90
CH=240
CYA=50
Thanks.
tl
