Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Just got TF100 today - first results
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Hello everyone - pumped my tf100 just arrived today and my pool water looks rough as expected lol. I am actually surprised my CYA isn't super sky high though because I used a ton of shock and tablets before I discovered this site. Anyways...
    Total Chlorine - 0-.5 - couldn't tell exactly
    PH - 6.8
    TA - 70
    CYA - 0
    Will fire up pool calculator shortly here.
    17x32 Legacy Pool / Deck built around entire pool / Hayward EC40C92S Perflex 1-Horsepower Extended-Cycle D.E. Filter / Dolphin DX-3 / GLI Cyclone Solar Cover Reel / TF100 Test Kit/Raypak 266k BTU Cupro Nickel Gas Heater
    Pool/Deck Install Finished Finally!!
    Jun 2014
    15,103
    Re: Just got TF100 today - first results
    Great! Congrats on the arrival of your kit. VERY amazing your first test showed no CYA. Make sure to ask us if you have any questions about performing the test.
    Actually you "did" post results. I meant more like perhaps a second set just to confirm. Sure seems odd about that CYA. It would also bee good to see your FC.
    Donldson's Avatar
    NW Ohio
    2,893
    Congrats on getting the kit.
    Is there a reason you didn't run your FC/CC or CH test? The FC/CC test is far more important than TC. In fact the yellow OTO test really just verifies that there is chlorine in the pool.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    How exciting that you have your Mad Scientist Play Set.
    You should run all the tests before you start playing with poolmath. Videos showing how. With the FAS-DPD test, there will be no doubt what the FC level is, and you can also test CC. It looks like you just used the OTO test alongside the pH tester. Did the CYA sample at least get a little cloudy? And even though low CH shouldn't be a problem, high CH could be, so you should know what it is.
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Nope no reason, just about to do it now.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    LOL the cya test.
    narrator SAYS "with back towards the sun" but the guy is facing it in the video.
    Dolphin E10 Cleaning Robot.
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    fc - 1
    Cc - 1
    Cya - 0 again mixture appears clear maybe a little grainy but I can still see dot
    Ch - 300
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    I was actually concerned I was going to have to drain my pool. The cya after thoroughly mixed and waiting still never blocks my view of dot.
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Just tested cya for the third time and still saying 0. What % chance is user error me being an idiot and what chance is there that there is no cya in my pool that I have incorrectly shocked and pucked? 95% I'm an idiot 5-% right? Lol
    Donldson's Avatar
    NW Ohio
    2,893
    Don't happen to have an aquarium ammonia test around, would you?
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Quote Originally Posted by Donldson View Post
    Eek - no
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by Chuppa3 View Post
    Eek - no
    Dump in 10 ppm chlorine and give it 30 minutes to mix and then retest FC & CC. That'll tell you all you need to know.
    Donldson's Avatar
    NW Ohio
    2,893
    +1 on this.
    Problem is that sometimes mysteriously low CYA levels means a bacterial conversion to ammonia. This often happens while a pool is closed for the winter and loses all FC so the bacteria can munch away on the CYA in the Spring before the pool is opened. In these cases the pool loses most or all of the CYA from last year and will have an incredible chlorine demand. So add the 10 ppm worth of chlorine and retest after a half hour. If you get a low FC and high CC reading after that then there might be an issue.
    If, however, you test and still have near 10 FC and a relatively low CC then you may have just gotten lucky and lost CYA other ways. Hoping for that outcome!
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Pool calculator says to add 72 oz of 8.25% bleach. How much would 10 ppm be? Sorry for noob questions and thanks you two for your help.
    Richard320's Avatar
    Jan 2010
    18,995
    We can't tell you that. We don't know how much water your pool holds. You've given us the size but not the depth so we can't even guess at the volume. Without the volume, poolmath won't work. It's not hard if you know the volume. You just enter the volume up top, plug in your current value and your target and how strong the bleach is an it tells you. How to Use Poolmath Tutorial.
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    I have 128 oz of bleach on hand - seems like I should just pour it all in.
    Ok yeah I got it Richard - thanks again. I was just confused when you said ppm. 16,300 gallons 17x32x4
    Richard320's Avatar
    Jan 2010
    18,995
    What strength bleach? And is it really 128 oz, or the new improved 121 oz? If you plug your 16,300 in at the top and then go waaaay down to Effects of adding chemicals, it will tell you how many ppm FC you added.
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Yes I see that now. Thank you for that. I use 64 fk oz tubs of 8.25%. I put one in just now and it added 2.6ppm.
    I apologize for being an idiot, thanks for the help.
    Donldson's Avatar
    NW Ohio
    2,893
    Never apologize for being an idiot, it makes all the other idiots feel insecure
    I kid of course, we were all new to this at one time so don't sweat it. Let us know what your FC and CC reading is in a half hour.
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    18,995
    You're still learning. It's a pretty steep curve at the beginning, and then it clicks. And then you'll be answering questions.
