Thread: Really stupid question - does the big o ring on intake / outlet go inside or outside
    Jun 2015
    Uk
    2
    Hi There.
    Apologies for the stupid question - should I put the big o ring on the inside wall of the pool (AG Intex 18'x9') or on the outside ? - I am talking about where the inlet / outlet connects through the wall to the filter Hoses.
    reason I ask is that I have a small leak at the outlet - most likely due to a slightly deformed o- ring (the smaller one that sits at the join of the hose to outlet connection) - I've lowered the water level so I can change it and while I've done that I thought I would check that I've put the big o ring on the correct side to start with (it was previously sitting against the inside of the pool wall on both the inlet and outlet holes).
    thanks for your patience - from an absolute novice Brit.
    cheers
    geoff
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    Re: Really stupid question - does the big o ring on intake / outlet go inside or outs
    I'm not 100% certain, but I think mine are on the outside.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Inside definitely.
    Putting it on the outside will highly deform the gasket when you attempt to tighten the nut down on top of it. It will twist and bulge.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Jun 2015
    Uk
    2
    That's great - thanks also for the schematic. Really appreciate it. Cheers
