Thread: Pipe-work question
    Jun 2015
    London
    3
    Pipe-work question
    Hi,
    Renting a house with a pool & have just opened it up for the summer for the first time.
    Have a question about the inlet pipes to the pump. There are 3 - one for the skimmer, one presumably for the drain at the bottom of the pool & one labelled 'waste'. No idea what this could be for & have left it closed - circulation system seems to work ok without it.
    Any idea why this is labelled 'waste' & whether I should leave it closed?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pipe-work question
    Welcome to TFP!
    Maybe a valve added to the waste line to control leaking caused by a bad gasket in the multiport valve. Maybe an outlet from the pump to allow you to drain water from the pool. We'd need to know what kind of filter you have and where it is in the plumbing to know for sure. Pictures would be a big help.
    38,271
    Welcome to TFP!!!
    That is certainly odd to have something labeled as waste on the suction side.
    Likely you could just ignore it ... or ask the owners ... or open it and see what happens
    Picture of plumbing?
    Jun 2015
    London
    3
    That was quick!
    It's a sand filter, picture of plumbing: Imgur
    Thanks
    That was a seriously quick response.
    It's a sand filter, image: http://imgur.com/Gu1JhEs
    Thanks!
    38,271
    In the future, click the "get embed codes" at the bottom right of the picture and then copy the BBCode to paste into the post like this:
    It could be that the waste is the floor (so you know to use it if pumping water out) and the other 2 are a skimmer and a wall suction line for a cleaner?
    Or the waste could be for a cleaner?
