Thread: Pentair Intellifo Questions
    1) I have leaks when my pump goes any higher than 2000 rpm. Was wondering what I need to do to stop the leaking
    Linking to a video
    Pentair intellifilo - YouTube
    2) If I want the pump to run 24/7 on the lowest speed 1, and for say 3 hours at a high speed how would I do that?
    Do I set speed 1 to be on 24/7, and say speed 2 to run for the 3 hours at the speed i want? And if so, how do I set speed 1 to be 24/7, it seems like it needs at least a 5 minute interval to stop / start between other speeds
    3) How do I stop the vibrating at lower speeds? Is there like an anti vibrate pad or something?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Pentair Intellifo Questions
    I am no help on 1 and 2. My pump does vibrate on some lower speeds, I just bumped the speed up/down 5 or 10 rpm until it stopped.
