Thread: Strainer placement
    Jun 2015
    West Allis WI
    1
    Strainer placement
    Hi- we bought the 16x48 intex pool n the set up for the strainers etc... Is a little different than past pools I've had. The directions are not helping. Needing assistance in how to finish setting up.i have the hoses connected on outside but not sure what goes on inside w: the black openings? Both strainers ? The filter w/ the movable direction piece is in the 3rd hole opening? Unless that's wrong? I'll post pics once I figure out how...
    Thanks for any help..
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Strainer placement
    Welcome to TFP!
    To post a pic upload it to photobucket then copy the IMG codes for the pic and past it here.
    Strainers should go on the inside
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
