Thread: Hayward Ph Sense and Dispense
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Does anyone have a Hayward Ph Sense and Dispense using C02 and can help with sizing of the co2 bottle?
    I'm still waiting for a call back from Hayward, but even they seem a little confused and my initial answer was "Well, most I've seen have a bottle about two feet tall".
    I know it depends on MANY factors on how much is dispensed, but looking for a rough idea on how long a 20 lb. bottle would last. Weeks, months? Do I want to drive further to refill or exchange a much larger bottle, or will a source of smaller bottles near me do if not having to exchange it weekly?
    Otherwise, has anyone else used the sense and dispense with both Co2 and muriatic acid and any input on what they liked using?
    I'm in no rush, my new pool equipment pad is finally almost ready so the new controller, pump, salt cell, will all be active soon. Just looking for the next add-on
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    38,463
    Re: Hayward Ph Sense and Dispense
    Have you searched the forum for discussion about the use of CO2? IIRC, it is generally not recommended, but I do not remember why.
    Mar 2015
    380
    Well, I'm also finding the ORP sensor to control the chlorinator also has a lot of possible complications. Back to the bottom of the maybe list and I'll worry about it later Either way, it sounds like using it with a dosing pump is just as easy to do compared to using CO2.
    Thanks!
    Scott
