Thread: Sand on my driveway
    Sand on my driveway
    When I backwash my sand filter for my in ground pool, I have noticed small amounts of sand accumulating at the exit hose which drains onto my driveway. What is the fix?
    21,000 gallon, 30' round AG pool (new install in 2013)
    Hayward SwimPro SW256T sand filter, Hayward SwimPro Voyager 2HP pump
    Pool Pilot Dig 220 SC-48 SWG
    Taylor K-2006 FAS-DPD test kit
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    Re: Sand on my driveway
    Define "small amounts".
    There's going to be some sand blown out along with all the crud and debris, but it shouldn't be nearly enough to impact the effectiveness of your filter.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Sounds normal to me. On backwash, everything gets churned up pretty good. and it doesn't have to pass through the slits in the laterals. Check out some of the cutaway pictures in this thread to see.
