Thread: Pool Renovation
    Jun 2014
    Sykesville, MD
    3
    Pool Renovation
    This is my first post to TFP, even though I've been a stalker for a while now. Getting ready to undertake a renovation (plaster/coping, new deck, etc). I think I have grasp on the project but I have a question and I wanted to get opinions. After 15 years of having a pressure side cleaner, I have decided to go with a robot. My question is, what should I do with the pressure side return line, since I will not be using it any longer. Should I just leave it in case I should want to return to a pressure side cleaner, this giving me options in the future. Just wanted to see what some of your thought are?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool Renovation
    I would leave it as-is. I would just turn off the valve that controls it. As you said, it gives you, or the next owner, the option of going back to a pressure-side cleaner in the future.
    May 2015
    Fort Lauderdale, FL
    8
    Re: Pool Renovation
    Leave it, either screw on cap it or at minimum spring loaded shut off cap. For future options.
    Apr 2015
    Finksburg, Maryland
    9
    Re: Pool Renovation
    Good luck with your renovation! We just completed a smaller project (tile, coping, and plaster) just down the road from you in Finksburg.
