Thread: Water from Balance Tank to Pool.
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Hi All.
    It seems bit of a daft question, but how do you put water from the Balance Tank into the Pool.
    Still learning.
    Bill.
    We have a in ground 10 x 5 Overflow Pool. All tiled in pale blue with dark blue at the top. In the pump room is the usual sand tank with a multifunctional thingy and a pump filter and timer.
    Bill.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,668
    Re: Water from Balance Tank to Pool.
    Balance Tank? I am not sure what you mean. Can you take and share a picture of what you mean.
    Kim
    trncbill's Avatar
    May 2015
    Nicosia Cyprus
    15
    Quote Originally Posted by kimkats View Post
    Kim
    Hi kimkats.
    Thanks for your reply, but have worked it out. We have a separate balance tank which holds about 10 tons of water. we get the water delivered into the balance tank, which then supply's the pool. Then when the pool is on overflow it draws water from the tank. Also we put all the chems in there as well. Then we just have to keep our eye on the levels in the balance tank. Don't know about all you guys, but our pump room has no drain and in the winter we can get a lot of rain here. I have heard stories about the pool guys running around when the rain is really heavy and having to pump the rain water out of the pump room. So looks as if that's a job before the winter sets in. Should be fun.
    Cheers.
    Bill.
    Bill.
    Jul 2012
    Tallahassee, FL
    30,668
    It is so interesting how things are done in other areas. Thanks for sharing. I still would like to see a pic if you have a min. Sounds neat.
    Kim
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey Bill,
    Is this a Zero/Vanishing edge pool?
    Essential Links:
