Thread: How Can I Keep my Above Ground Pool Cool?
    What are ground pool tools are required? From where I can buy high quality and low price above ground pool tools? Can you please suggest me?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,390
    Re: How Can I Keep my Above Ground Pool Cool?
    Heritage Floating Grecian Fountain - Walmart.com
    Something like this will help. Please know that it will also raise your PH over time.
    Kim
    Casey's Avatar
    SW PA
    10,421
    Run the pump at night without a solar cover.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Aeration at night, by running the pump along with a fountain, will do the trick.
